Can anyone help me please. My 850 acts like it is not getting fuel once the engine is at running temp.
I have replaced the fuel filter, fuel pump, idle control valve, and mass air flow sensor. I am at wits end. I really want to get her on the road again. It has been a great car till last week.
850 stalls once at running engine temp.
White850Turbo
- Year and Model:
IIRC, it's the red one. Should be near the top. It should be marked "fuel pump relay" or something to that effect.
-Sean
1998 S70 T5 (Almost Stock)
HELP, I have replaced the fuel pump relay, $130bucks and no change.
cleaned the FT. and car runs great till normal engine temp.
If I give it light gas. it will run, but if I put too much pressure on the gas, then the car sounds like it is starving for fuel and engine quits. I will not restart till engine cools a bit. I am not sure what else to do.
I have done everything except the O2 sensor and the cam sensor.
does any one have an idea.
Thanks,
desperate volvo driver.
Thanks,
- Has thanked: 2865 times
- Been thanked: 1332 times
Vacuum lines? In an unlikely scenario the engine could be heating the lines up to a temp where a crack or cracked elbow gets large enough to introduce extra air into the mix. A guess.
White850Turbo
- Year and Model:
They charged you $130 for a fuel pump relay?!?!rmmartel wrote:HELP, I have replaced the fuel pump relay, $130bucks and no change.
Thanks,
I agree with Matthew on the grounds that heavy throttle pressure is what kills it. Especially take a good look at the vacuum elbow on the passenger side of the intake manifold (assuming this is a turbo model).
-Sean
- 1789 Views
Last post by ejbj
- 481 Views
Last post by Dieudonne
- 1177 Views
Last post by SSTurbo
- 1385 Views
Last post by FLXC90
- 1337 Views
Last post by richardgengle
