Did you know? 🤔
2005 V70NAM56 CATHERINE Manual 5 into code:xxxxx. Saurus 15inch wheels
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
Has thanked: 363 times
Been thanked: 1109 times
Trinidad & Tobago
Re: 2005 V70NAM56 Barents Blue Manual 5
Post by abscate » Mon Oct 08, 2018 7:04 am
Removed rear wheels, inspected parking brake shoes/drum
All ok
Removed center console, adjusted parking brake to 4 clicks full application, tested release
viewforum.php?f=9
Link To Volvo Glossary
Trinidad & Tobago
Post by abscate » Sun Dec 02, 2018 6:18 pm
120,025
Oil change filter Mobil 1
New air filter
Will send oil to Blackstone
Screen Shot 2019-01-03 at 8.42.22 AM.png (131.46 KiB) Viewed 381 times
Trinidad & Tobago
Post by abscate » Thu Jul 25, 2019 12:22 pm
Replaced Cabin air filter CUK 2850 at 1228xx
Tailgate latch is inop. No continuity from REM connector pin to tailgate solenoid wire at solenoid. Probable wire loom failure. viewtopic.php?f=9&t=89038&p=519123#p519123
26 OCT 2019
With cooler weather, the previously seen BCM-0700 has stopped occurring
viewtopic.php?f=9&t=85197&p=482578&hili ... BS#p482578
Xmodex repair is $750 for both module and Pump
https://xemodex.com/us/product/brake-co ... -volvo-p2/
Trinidad & Tobago
Re: 2005 V70NAM56 Barents Blue Manual 5 into code:xxxxx. Saurus 15inch wheels
Post by abscate » Sat Jan 04, 2020 5:36 am
And it’s a New Year, 2020
CanBus H L infor from swedespeed
https://forums.swedespeed.com/showthrea ... LVO-CANBUS
CANfoolery
So in the past few months there has been alot of talk about 4C, good and bad. Some want to remove everything to do with it on their cars, some want to use different shocks, some can live with it etc. Then there is talk of fooling or tricking the system somehow. This leads me to my post. Are there swedespeeders out there who would be willing to "tag-team" sniffing the CANBUS to understand messages and possibly manipulate/trick/control/read/whatever 4C and other parts of the car? I figure we can use this thread as a master to post ideas, wish lists, deciphered CAN messages (that would be nice!) etc. then maybe we can get somewhere to modding the car's core systems.
I have already purchased a http://www.canusb.com device and have been trying to detect activity on my 04 SR without any luck (although I haven't really dove into it....yet).
To start here is some basic info:
04' - CANL - speed = 125kbps, CANH - speed = 250kbps
05+ - CANL - speed = 250 kbps,CANH - speed = 500kbps
Main car units (i.e. ECU, CEM, ABS, SUM etc) operate upon CANH bus
CANL reserved for things like DIM, windows, audio etc
CANbus is detectable @ the OBD port (reportedly)
CANbus is POSITIVELY accessible via a green 10pin square connector in trunk (RTI connector)
Other posts of interest:
https://forums.swedespeed.com/z...age=1
https://forums.swedespeed.com/zerothread?id=38911
Here is a small wishlist of things that I'd like this project to lead to and/or accomplish:
fob - yellow - turn on drls("follow me home" lights) or open windows/sunroof
advance button - turn off dtsc completely
write to messages DIM
make horn beep on lock/alarm engage
cancel bulb out message
cancel 4c suspension not working message
Trinidad & Tobago
Re: 2005 V70 NA Baltic Blue Manual 5
Post by abscate » Fri Mar 06, 2020 9:16 am
2020 maintenance record
abscate wrote:
Sun Nov 22, 2015 12:24 pm
Tailight failure, both sides
Diagnosed and repaired
http://www.matthewsvolvosite.com/forums ... =9&t=73056
Rinse and repeat on this one today, same fuse in REM
Added one liter make up oil at 126400, 10 March
25 July 127600 oil and filter change 10W-30 Mann. These oil changes are killing me
Trinidad & Tobago
Re: 2005 V70NAM56 CATHERINE Manual 5 into code:xxxxx. Saurus 15inch wheels
Post by abscate » Fri Jul 31, 2020 5:18 am
Temp sensor specs
