I have searched a bit and can't find anyone who's had the specific issue I'm having. I changed the timing belt, tensioner, idler pulley and water pump on a friends 2001 s80 turbo. Car runs smooth now, doesn't leak coolant or overheat and he's very happy. My concern is the timing belt area has a faint groan now and I'm concerned that I may have done something wrong. Since I didn't listen to the car before (mistake) I don't know if the groan was there prior to my work. I've done several timing belts, but this was my first experience with a mechanical tensioner, my 850 has a hydraulic one. Should I be worried about his car? If the belt is a bit too tight could it cause groaning or other problems? Are faulty NEW parts likely?
Thanks in advance...
2001 s80 turbo - groan after new timing belt...
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
There are cheap tensioners on the market that can cause troubles. It's even worst with cheap water pumps.
Is the belt centered on the pulleys with no friction on either side? The mechanical tensioner usually has a temperature needle that needs to be set in the middle at room temp. It also has a specific way of putting tension on it.
Thanks. The tensioner was INA I think? I ordered it in a kit from FCP. I set the needle in the middle as it was about 70 degrees here today and the engine was cold. After running the car a few minutes though the needle was well past the little "window" towards the right (about1:30 maybe?). When the car is hot is this needle movement normal? If so, then I'm not worried about the tension causing the groan.
THAI UNG
- Year and Model: 2007 V70 2.5T
- Been thanked: 4 times
Several years back when I did my second timing belt job on my s80 non turbo and I got the groaning sound too.The sound came from vvt cam pully unit(mine is on the intake side).The belt itself was a tad on the tight side,so I reset the belt tensioner a bit to the loose side to relief the tension on the cam pully and the problem solved.Hope it helps...
Since I complain about threads with no closure, where a question is asked, discussed and suddenly abandoned; I am happy to report that it was in fact simply that the tensioner was a bit tight. I loosened the belt slightly and the groaning noise disappeared. Thanks for the help, I appreciate it.
- 412 Views
Last post by FireFox31
- 23 Replies
- 17096 Views
Last post by jonesg
- 326 Views
- 14 Replies
- 4373 Views
Last post by johnrapier
- 968 Views
Last post by Crumpler
