1996 850R Require ECM
FLY 753 GP
- Year and Model: 850R 1996
My service dealer were unable to fix my 850R and proclaimed an ECM is unobtainable anywhere. I am now starting a private search for the part.
- phils94850
- Year and Model: 2009 s60 turbo
Check on ebay... sometimes youll find one for sale as a upgrade. Is your car an automatic trans ?
1996 Platinum Edition
- Has thanked: 2199 times
- Been thanked: 1851 times
Also try the usual suspects (I'm assuming the Pretoria is not the South Africa one).
1) Erie VoVo
2) vandsautodismantlers in California
3) Chapman Motors On Vancouver Island in Canada.
1) Erie VoVo
- Has thanked: 311 times
- Been thanked: 817 times
You can use a non-R ECM, i.e. one from a turbo car with the same kind of transmission, with no problems whatsoever. A regular turbo ECM puts out a few less horses at the highest RPMs but the difference is barely noticeable. Just match the emissions setup (±air pump, ±EGR) to avoid a check engine light. Basically a 96-97 ECU is what you want. If your car has EGR and an automatic transmission then I'd be happy to sell you my 95 R ECU but you should be able to find one local no problem (assuming you *are* in South Africa).
As a side note, ECM failures are very rare and your dealer may be wrong ... at the least they should have known that an R ECU is not required, e.g. for testing purposes.
- phils94850
What problems are you having with your car exactly ?
FLY 753 GP
Thank you to all who responded. Yes, Pretoria South Africa, and the car has automatic transmission. The car merely cut out (immediately, i.e. without stuttering) just after I had started it. Thereafter it refused to start (as though there was no spark). The dealer diagnosis indicated flooding, explaining the ejectors were not operating properly and continuously pushed through fuel. I also suggested we use a non-R ECM, but they insisted it cannot be done - they said it "would not map". To what I asked? They had no reply. I will follow up on the various options suggested, thank you. If at least I can just get the car going, albeit with a little less power. Thank you all. René Oosthuizen
- phils94850
The car just cutting out is usually a cam or crank sensor and wont re-start. Not the ECM. As stated earlier the failure rate of the ECM in our cars is very low. I had one do this to me, after replacing the cam and crank sensors it ended up being a bad coil so id check that as well before replacing the ECM
Have a good look at the connector to the ECU for dirt, corrosion, or possibly incomplete seating.its much more likely to be a connector issue than an ECU issue.
FLY 753 GP
Thank you for further feedback. One thing is clear to me, I should try a few other potential culprits before pursuing the "defunct ECU" route. I will advise once I have had time to investigate the matter further.
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
Most tech that works in the dealership are probably not old enough to know about anything about 850 made in 96.FLY 753 GP wrote:I also suggested we use a non-R ECM, but they insisted it cannot be done - they said it "would not map". To what I asked? They had no reply.
I have a 96 R-ECU in my 94 Turbo 855. Works just fine.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
