1998 S70 Error codes - P0107 and P1308
aswresm
Year and Model: 98 s70
Post by aswresm »
Got error codes P0107 and P1308 ......first changed the acceleration sensor and the P1308 error code disappeared....Got anew Barometric sensor to fix error code P0107 and once installed I got the check engine light with both codes again (P1308 and P0107)...Now I am stuck with both error codes.....I kept looking online for any reason that might trigger both errors at the same time but no luck....Also I found a hanging brown sensor wiring connector coming from the same wiring harness that's feeding the Headlight , the Map sensor and the acceleration sensor...The thing is I have no Idea where this connector goes or connects to....It's a three bin brown connector with part number 977929 on it and it's made by Volvo.....Looked online and it says that it is a black connector for ac Map sensor but my connector is brown.....And also where is the Ac map sensor is located exactly.
I would greatly appreciate any inputs on this issue!!
Thanks
aswresm
Post by aswresm »
Ben850
Been thanked: 7 times
Post by Ben850 »
That is either for headlight wipers, if you do not have them, or fog lights.
If so, there will be another on the other side.
Whichever are not installed.
Another thought could be rear washer fluid pump for V70. In that case, just the one.
Either way, it is for an uninstalled option, and has the clip to hold it to the chassis at some point.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Has thanked: 2202 times
Been thanked: 1852 times
If I remember what I was recently told, the A/C sensor is also on the same circuit as the other 2 sensors.
I believe it to be the one at the back RH side of the engine compartment shortly before the A/C pipe heads through the bulkhead.
aswresm
Post by aswresm »
scot850 wrote:If I remember what I was recently told, the A/C sensor is also on the same circuit as the other 2 sensors.
So that would be the low pressure ac sensor.......The one that is on the same circuit though would be the Ac high pressure switch.......Which is actually located underneath the Map sensor location....Please advice if I am mistaken...
Thanks
aswresm
Post by aswresm »
http://www.ebay.com/itm/Volvo-C70-98-04 ... dd&vxp=mtr
Is this is the one you are talking about??
aswresm
Post by aswresm »
Sorry I was mistaken as the one near the firewall is the high pressure switch....any idea how to replace that??
Ben850
Post by Ben850 »
You are no longer talking about the un-used connection. It has never been used. It still has the rusty clip from assembly.
aswresm
Post by aswresm »
Yes Ben, Thanks for the info....I am trying to find a way now to replace the ac switch so I can clear the cel.
