1994 850 manual Oil Loss.....No Visible Leaks
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Been thanked: 3 times
Post by shaker_chi »
I have an early 5 speed 1994 850 with 206,000 miles. For the past 6 months I am losing about a quart of oil every 1,000 miles driven. When I look underneath I don't see any leaks and I check my car every morning and don't see anything on my garage floor. Any suggestions?
Has thanked: 1610 times
Been thanked: 4068 times
That is slow enough loss that you might be burning it (rings, valve guides) without seeing any oil on the plugs or the exhaust. You can drive for a long time like this. Keep an eye on that oil though.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
When was the PCV system last serviced?
85 GLH, 367 whp
00 Insight, 72 mpg
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
If you cant find an external leak then you need to do a wet/dry compression test to see the condition of your piston rings.
1996 Platinum Edition
shaker_chi
A PCV was done at 200,00 and at 165,000 before that. It's 15 degrees in Chicago today, so as soon as I get a day over 30 I'll do a compression check. What should I expect from the compression test?
phils94850
Normal dry compression is around 140-170 I think
shaker_chi
Last time I check the oil I added STP oil treatment instead of the usual 5w30 and I have not lost any oil in the past 6 weeks. What effect does the STP have on the oil? Obviously, it will thicken it up, but how does this reduce my oil consumption? Just trying to understand the science behind it.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
It's simple.It makes the oil thicker,so it can't pass by the old valve stem seals anymore like it did before threatment.
You would have the same effect if you switch to higher viscosity oil....like 5w-40 or 10w-40.This "40"counts,because it is thicker at operating temperature than "30".
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
