Did you know? 🤔
2008 Volvo XC90, 3.2 AWD, Transmission Flush
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
ggleavitt
Year and Model: XC90 05-2.5T, 08-V8S
Has thanked: 0
Been thanked: 56 times
United States of America
ggleavitt
Re: 2008 Volvo XC90, 3.2 AWD, Transmission Flush
Post by ggleavitt » Mon Dec 02, 2019 4:16 pm
http://www.timthurber.com/volvo-xc90-3- ... c-6-speed/ is a good post to review, as is this- https://forums.swedespeed.com/showthrea ... luid-flush
As noted, a TF-80SC is a TF-80SC, no difference between the engines as far as fluid replacement. Step noted for resetting fluid counter after replacement, requires connection to vehicle using a Volvo compatible tool (VIDA/DICE as example).
Some do a full pump-out (I do 16 qts the first time, 12 thereafter), some do drain and fill (3-4 quarts at a time). Either way, transmission takes >8 quartz of fluid (JWS3309 until chassis 568000, then BOT324/JWS3324 for chassis >568001). Changes as noted in viewtopic.php?f=10&t=84764
2005 2.5T AWD-198k
2008 V8 AWD Sport-129k
T5AUS
Year and Model: 08 XC90V8 94 850T5
Has thanked: 0
Been thanked: 0
Australia
T5AUS
Post by T5AUS » Mon Dec 02, 2019 4:54 pm
Thanks for that BKM
1994 850 T5
2001 V70 T5 (Sold)
2008 XC90 V8
skippyxc90
Year and Model: XC90 3.2 AWD 2008
Has thanked: 0
Been thanked: 3 times
skippyxc90
Post by skippyxc90 » Mon Dec 02, 2019 7:51 pm
I have a VIDA DICE 2014D. It spits out anything for Volvo vehicles from 1999 to 2014. Give me the model of your XC90 and I'll be glad to generate and post the steps.
You should know that to properly check the trans mission fluid, you must idle until the transmission fluid reaches 50 to 60° Celcius. All excess fluids will overflow and that's where you screw in the Integrated Level Plug bolt.
Without knowing the fluid temp and or not having a VIDA DICE to gauge the temp might give you inacurate result.
Turbo_Boss
Year and Model: 2008 XC90 3.2AWD
Has thanked: 7 times
Panama
Turbo_Boss
Post by Turbo_Boss » Mon Dec 02, 2019 8:13 pm
Hey Guys,
I am going to change my ATF Fluid on my 2008 3.2 XC90 and since I am ordering some parts to a Volvo Dealer, I will appreciated if you can help with some part numbers.
I have check the schematic diagram on the Volvo Parts and don`t find the part number for the big and small crush washers that`s goes in the Transmisión Draining Plug: https://pasteboard.co/IJtBdcC.jpg and this: https://pasteboard.co/IJtDhud.jpg
Also need the part Number for the Washer or O Ring that goes in the Filler Plug that`s goes in the top of the transmisión housing : https://pasteboard.co/IJtCzEZ.jpg
Thx for your time and help
Isaac
2008 VOLVO XC90 3.2L AWD
2008 TOYOTA Prado 2.7L 4x4
2009 VW Jetta 2.0
skippyxc90
Has thanked: 0
skippyxc90
Post by skippyxc90 » Tue Dec 03, 2019 12:13 am
skippyxc90
Has thanked: 0
skippyxc90
Post by skippyxc90 » Tue Dec 03, 2019 12:17 am
Transmission Drain Plug washer
These users thanked the author skippyxc90 for the post:
Turbo_Boss
skippyxc90
Has thanked: 0
skippyxc90
Post by skippyxc90 » Tue Dec 03, 2019 12:19 am
The Filler Plug rubber o ring is not critical. The crush washer and the Integrated Level Plug rubber o ring is a "MUST"
Turbo_Boss
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 26 times
Been thanked: 51 times
MoVolvos
Post by MoVolvos » Tue Dec 03, 2019 1:07 am
Just in case you need other parts Turbo_Boss.
https://usparts.volvocars.com/Volvo_200 ... ssion.html
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
MoVolvos
MoVolvos
Post by MoVolvos » Tue Dec 03, 2019 1:11 am
T5AUS wrote: ↑
Thanks for that BKM
Hope it helps T5AUS. Here is someone checking the level without the software (after all the other work).
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
Turbo_Boss
Panama
Turbo_Boss
Post by Turbo_Boss » Tue Dec 03, 2019 10:35 am
skippyxc90 wrote: ↑
Hey Skippyxc90,
Thx for the part numbers.
Isaac
2009 VW Jetta 2.0
