My daughter hit the wrong pedal while parking her car today and hit a wall hard enough to cause the passenger airbag to deploy. Looking at the car we can also see that she hit it hard enough to push the front corner back just enough to increase the gap between the hood and the wing to about 5mm.
I don't care too much about the cosmetics, just looking for guidance here on what I need to do to replace the airbag and reset the SRS warning. Also I guess I probably need to replace the interior piece that covers the whole dash (I really don't know what that's called).
Any thoughts?
Thanks,
Ian
2003 s60 Passenger Airbag Deployment
maddog2020
- Year and Model: 2003 S60 2.4T
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Indeed, the dash needs to be replaced. Was there a passenger in the front seat? Usually, the safety belts have a pyrotechnic retractor (pretensioner) that can also be activated when the airbag deploys, and it's important to have it replaced as well (for the seats that had passengers when the impact happened).
JRL
- Year and Model: Several
- Been thanked: 16 times
You have obvious unibody damage.
Unless you straighten it out it will ALWAYS be out of alignment
maddog2020
I had the alignment checked today and it's still fine, the damage is minor, so "obvious unibody damage" is a bit excessive.
Good info on the pre-tensioner. There was nobody in the passenger seat. The driver's side seat belt still feels completely normal. Is there any way to check if the seat belt pre-tensioners have triggered?
Thanks,
Ian
Thanks,
Ian
- 7290 Views
Last post by jimmy57
- 19 Replies
- 2936 Views
Last post by FireFox31
- 966 Views
Last post by dudeitssm
- 3268 Views
Last post by 93Regina
- 1086 Views
Last post by packetfire
