1998 S70 T5 Swirling Sound- need a starter?
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
So a day or two ago, I turn the ignition key and I hear a swirling sound as my car is trying to fire up. The time is taking longer now for the car to start with a longer swirling sound before it catches. Just wondered if this is the sound of a starter motor that is going south or if it could be something else (like the battery- but the battery is only a year or so old)? If I can get confirmation it is the starter, I'll go ahead and replace that before I'm stranded somewhere, especially at night in the cold.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Holy cow! MIJ is back! Sorry, I have nothing useful to contribute here.
instarx
Year and Model: XC70 T6 2011
Has thanked: 1 time
Post by instarx »
Welcome back MIJ!
Your problem sounds just like my problem a year ago. Starter going bad. From personal experience my best advice is not to get a couple of "good ol' boy" mechanics in East Tennessee to replace it for you! Trust me on this, it took a week to fix what they broke. lol.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
Yeah sounds like a starter. Welcome back MIJ !!
1996 Platinum Edition
Thanks guys- I still lurk on occasion- LOL. I would replace this myself anyway I would not allow Shadetree mechanic to touch my car I have learned the hard way! That said the starter is really two pieces the starter motor itself and a solenoid that's hooked to it - the smaller piece on top. Does this sound like a starter motor or the solenoid or is it just best to replace them both at once?
Btw I had to replace that starter a couple of years ago but because I was in a hurry I sourced a used local one with a short warranty- grrrr!
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I replaced my starter last year because the car wouldn't turn over when it was warm or rainy out. I thought it was the starter but the root cause of the problem turned out to be a corroded positive battery terminal cable.
The swirling sound you describe makes me think of the sounds a worn out or broken gear, lever or spring in the solenoid or motor might make, but I'm just guessing. Would it be helpful to use a stethoscope on the starter when it's acting up to help pinpoint or confirm the source of the noise?
Has thanked: 1610 times
Been thanked: 4065 times
Im still having trouble hearing that sound in my head...not usually a problem for me, when they let me out of my padded room.
Its common for the small braid wire between the solenoid and starter to fail and make a good starter turn over slowly. I also used this fact on a recent starter problem and got my first valuable post on MVS in 2014, so Im sticking with it.
Definitely check battery cables and grounds before tearing your starter out.
Thanks guys I will check all those wires!! Funny thing is it all started fine today...
Has thanked: 2200 times
Been thanked: 1852 times
Sounds like the starter bendix spring is failing or the solenoid is weak. Replacing the starter is my suggestion. Check all the cables (particularly the earth cables) in the engine compartment area.
instarx
Has thanked: 1 time
Post by instarx »
MadeInJapan wrote:Thanks guys I will check all those wires!! Funny thing is it all started fine today...
That's typical. Mine was sporadic and kept getting worse. It was most reliable when the engine was cold but when it got heated up it would sprrrrr.
2011 XC60 - sold
