2000 V70R - E-brake shoe thickness?
Has thanked: 2210 times
Been thanked: 1852 times
Any idea what the parking brake material thickness should be? AWD vehicle.
Still have about 4-5mm on the shoes.
Wondering as I have it in bits, should I replace anyway (car will be up for sale in a few weeks) and don't won't to spend any more money, but also want a clear conscience!
Thanks,
Has thanked: 1611 times
Been thanked: 4075 times
That sounds pretty close to new, IMHO. Just adjust them in nicely (I think on the 2000 you adjust inside the wheel first, through the brake drum holes, and then at the lever only if needed.
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Check if the brake holds after adjusting. The adjustment should take care of slight wear. Lubricate the pivot points with anti-seize but your measurements sound okay.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Thanks guys. That's what I thought. Will carefully check for delamination of the shoe braking material as I've had an issue with a couple of AWD Volvos. Not sure if that is a problem with FWD also.
