1998 S70 Longitudinal rubber strips on roof
rnelson1020
Is there any way to renew or place the longitudinal rubber strips on the roof?
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
I picked some up in the yard for cheap when I took rails for my V70.
pretty simple just take your time.
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I think new ones cost about $158 each.
jaymorgan1
- Year and Model: 98 v 70 awd
When removed can roof rack rails be installed ?
- instarx
- Year and Model: XC70 T6 2011
- Has thanked: 1 time
I've never seen any, and I would have noticed that!
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
neworleans
- Year and Model: 2007 S60R
I painted those with Plastic Dip (you can get it at walmart), they came out really nice, you need to strip everything out first and than sand it down little bit, then tape it up, use some old newspaper to get a good coverage, if you do it outside make sure there is no wind. You will need to spray about 5 coats, wait about 5-10 minutes between coats. Be patient. Plastic dip puts a really light coat so don't try to cover it at 1 or two times. When you are done painting, be very careful when removing the tape, have a razor blade ready with you, you will need to cut the edges of tape.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Not by the factory, but it's been done.Atis wrote:Were there any factory roof rails for sedans as well?
There are some examples over at VS.
- 12 Replies
- 3503 Views
Last post by 98v70dad
- 15 Replies
- 9827 Views
Last post by kaneelschep
- 2745 Views
Last post by Archer
- 2342 Views
- 1271 Views
Last post by JimBee
