1991 240 no overdrive
I just bought a 1991 240 and it has no overdrive. The fuse is good, the relay is good and I am getting voltage to the solenoid. I replaced the solenoid because the rubber on the top of it was all rotted and breaking. With the new solenoid installed I still have no overdrive.....Does anyone have any ideas? I don't think I have ever seen one of these trannys fail... Thanks
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
If solenoid is working, then consider M46 Overdrive rebuild-Jonc123 wrote:1991 240 and it has no overdrive.
Notice the IPD instructions
These OD transmissions have a pump, and if pressure is low, OD will not engaged.
No simple fix here...Volvo 240 & 260 overdrive repairs & maintenance service manual
- 93Regina
You installed solenoid with two o-rings?Jonc123 wrote:Mine is an automatic....
You bought a new solenoid?
- 93Regina
Word for the Day: Kickdown CableJonc123 wrote:yes two o rings and a new solenoid
See: 1994 940 Non-Turbo Not Shifting into Overdrive
- 1386 Views
Last post by lummert
- 2834 Views
Last post by Nashsurecanpaint
- 644 Views
Last post by hankeester
- 1824 Views
Last post by 93Regina
- 657 Views
Last post by JDS60R
