98 V70 XC Spun Bearing?
supersquid16
Year and Model: 1998 V70 XC
Post by supersquid16 »
Greetings!
Hate to make this my introductory post to the forums, but I think our V70 XC may have died :cry:
We've had a slight tick for a couple months, but nothing I haven't seen/heard in others. Volvo mechanic even heard the car week before this happened. Was not very concerned by the noise, either. Decided (after lots of other work) to get the seals to redo the oil pan. Literally on the way back from Volvo of Tacoma and the tick turned into a violent knock. Got it towed back to my garage, where she now sits.
- Engine turns over, idles and revs
- Oil level full and clean
- No CEL
- No oil light
- No service light
- all idiot lights come on when I turn ignition.
Please see the videos below.
Also, here's a list of maintenance/repair done on the car since we got it back in January 2014:
2/14/14 - 142,033 Replaced front struts/wheel alignment @ Earley Tire ($487)
2/19/14 - 142,500 Axle & CV Joint replaced/engine ventilation system @ McLee’s Auto ($865)
5/02/14 - 145,405 Oil Change/code read & reset @ McLee’s Auto ($135.13)
9/12/14 - 149,048 Front Brakes: BrakeBest rotors ($89.98) & pads ($24.29) @ home
9/12/14 - 149,048 Oil Change (Mobile Synthetic 10W-30) @ Home ($30)
9/19/14 - 149,500 Front suspension work follow up @ McLee’s ($68)
9/28/14 - 151,016 Tires replaced Bridgestone Turanza Serenity @ Firestone ($528)
9/28/14 - 151,016 Lifetime Wheel alignment @ McChord Firestone ($120)
10/13/14 - 151,000 Rear Brakes: BrakeBest rotors ($66.58) Akebono pads ($36.43) @ home
10/25/14 - 151,500 Heater Core @home ($28.95) via eBay
11/04/14 - 152,233 Oil cooler lines, coolant flush, oil change, brake fluid @ Art Works ($594.37)
11/05/14 - 152,500 Full detail @ Too Easy Detailing ($191.28)
11/07/14 - Upper Strut Mount Bushing URO Parts @ home via Amazon ($18.12)
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
That sounds pretty grim, like a rod bearing which basically means he engine is toast. Installing a good used engine will be a much cheaper than trying to repair your existing one.
supersquid16
Sadly, sounds correct.
Perhaps parting it out is an option.
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Spun bearing is super rare with these engines, first I've heard on a stock engine/non heavily modified.
You can make a lot of money parting out the good engine bits: turbo, sensors, hard to fine pieces that can more than pay for a used engine.
Try to get an engine with good compression numbers.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Related thread below (Oil Sludge):
http://forums.swedespeed.com/showthread ... e-a-Diesel
Looks like oil sludge finally killed yours.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
A used engine from any kind of dealer or shop will usually not come with any sensors or accessories, almost certainly will not come with a turbo. Even if you pull an engine yourself at the junkyard, they will charge for those things, albeit not very much. If you want to part out the engine bits you would have to find a replacement engine from a private seller who is not parting them out himself. Maybe shop around first, factor that into the economics of your decision.
I dao agree that given all of the recent work invested, it would seem a shame to give up on this car. At the same time, engine swap on an AWD is something of a handful. Tough call.
Post by cn90 »
Just curious, what brand of oil filter do you use:
- Bosch
- Mahle
- Mann
- Fram
etc.
Post by cn90 »
According to the thread below, a bad oil pick-up O-ring in the pan can do this:
http://volvoforums.com/forum/volvo-s60- ... ing-46424/
Another VERY GOOD reading below:
http://atlanticmotorcar.com/volvo-s70-d ... p-pick-up/
BTW: for those of you who replaced the oil pick-up O-ring in the pan, what were the symptoms?
This way I know when to do it.
So, if I have no knocking noise and no oil pressure light, i.e., engine runs smoothly, then I should leave my oil pan alone?
Post by erikv11 »
I have done pick-up o-rings twice but both times the engine was out of the car. Once was an engine I had been running. I didn't notice any symptoms. The other time I bought the engine from a mechanic, he said it ran great (and it does now!). Anyway, both times the o-rings were crushed and a little malformed, was glad I did it. Engines were at ~175k each time.
Otherwise I do go by your last statement
cn90 wrote:So, if I have no knocking noise and no oil pressure light, i.e., engine runs smoothly, then I should leave my oil pan alone?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
If I understand well you haven't done yet the oil pan o-rings? Probably one o-ring just give up which I believe is pretty current on those years. How is the PCV breather doing?
If you are not afraid on getting messy, and given the money already spent on the car, you may try this more or less temporary trick
