97 850R - Car blew the 30A blower motor fuse badly
850_GLT_Owner
Year and Model: 93 850, 97 850R
Post by 850_GLT_Owner »
The 30A fuse(fuse #5 i believe) that controls fan speed 4 blew out badly. There is slight damage to the fuse box itself from the heat of the fuse blowing. Wondering if this would warrant a fuse box replacement or if this is one of those things that it can handle.
Is the fuse box relatively easy/straight forward to replace?
Thanks!
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Is something aftermarket wired to that fuse?
It's really unusual.
Climate control is designed to turn off blower completely and to inform driver with flashing ac/rec lights on the console that something is wrong with climate control.
Usually if the blower use too much current,ECC turns it off and it will not turn it on again untill the fault is solved.
Or...sometimes it will turn it on,but will immediatelly turn it off as soon as it sense that blower consumes too much current.Climate control do that to save resistors.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Ben850
Been thanked: 7 times
Post by Ben850 »
The previous owner of my wagon had become creative in bypassing the ECC unit.
While hard wiring the heater fan for the winter, the bearings were dry in the fan and deteriorated badly causing a short at the motor to ground.
He had toasted the fuse box fairly well at the same time.
I could see an issue.
The fan was shorting things with its burnt bearings.
The fuse box itself is likely fine. The fuse socket needed some cleaning. With dentist type poking tools, I was also able to bend the contacts back into their proper shape.
In my case, he had fried both #26 and #31 sockets.
Check the condition of your heater fan.
A sharp blade, contact cleaner, and some poking tools made it fine.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
