My 850 has tripped the P0442 code. I've been reading all the post for the code, and if I understand them , its probably a hose leak in the EVAP system. I'm going to spend time in the morning looking for a cracked hose. Many posts point to the J hose on the canister. Any other good places to look, other than following every hose and connection in the EVAP system. Where is the canister on the '96 GLT?
I don't have a lot of time between now and Christmas due to work constraints. If I can't find a quick fix tomorrow, is there any issue with driving the car until the end of December? I'm guessing there is not, and shouldn't be any affect on the catalytic converter or Oxygen sensors? If there is I may have to take it to my local Volvo specialist.
thanks!
96 850 GLT P0442 Code
joe_pinehill
- Year and Model: 850 1996
96 850 GLT
RIP '90 240 DL, 285K, someone ran a stop sign in front of me
RIP '89 760 Wagon, 200K
RIP '83 240 Wagon, rusted out
joe_pinehill
Are the j hoses available at part stores? or dealer online only?
96 850 GLT
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
It might be a good idea also to check the rubber hoses at the roll over valve near the fuel filter... that's where the damage was on my '97 855 GLT a few years back, though the code I got in that case was 0445 (large leak).
joe_pinehill
I followed as many lines as I could. The only cracked line I found was one of the lines on the air filter air box. The upper one on the lid of the box. I replaced the elbow with a generic from a mixed pack at the Autozone. I also replaced the Purge Valve, as far as I know its the orignal.
96 850 GLT
- 537 Views
Last post by xHeart
- 1489 Views
Last post by PeteB
- 1109 Views
Last post by neworleans
- 1261 Views
Last post by zwieback
- 642 Views
Last post by jreed
