2006 volvo c70 running rough idle
martin1981
- Year and Model: c70 2006
Were can I get some answers on my volvo c70 when it on tick over or idle it seems to be running rough in between 1000 and 2000 but when you get over 2000 it seems to run ok but not perfect thanks for help in advance there is no fault codes it was running fine till changed alternator but I dont think this has anything to do with it.
Can you please reformat or repost following our "no text talk" guidelines above. You will get more responses that way.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Which engine is in your C70? For north America There was only one engine, a B5254T. I am not sure if that is the case for UK. You may have a non-turbo or another engine.
martin1981
could you please tell me how i would find this information out please
martin1981
engine code is B5254T3 THANKS
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Two links for your consideration -
The correct forum section for your model year of car:
https://www.matthewsvolvosite.com/forums ... m.php?f=25
The english standards posting policy for MVS at large:
https://www.matthewsvolvosite.com/forums ... 25&t=44724
Best of luck.
Best of luck.
jimmy57
Clean the throttle. Look for metal filings. If metal is found then check turbocharger.
This is one possibility based on the ECM cancelling injectors when the throttle hangs open to lower idle speed. You do not mention any warning lights on. IS your Lambda lamp lit or is there a message about engine service needed?
- 420 Views
Last post by draser
- 1351 Views
Last post by Cees Klumper
- 732 Views
Last post by mrbrian200
- 11 Replies
- 4106 Views
Last post by straubman
- 2729 Views
Last post by DeadEric
