1994 850 car won't crank
warrenout
- Year and Model: 850 1994, 2015 XC60
Pulled car into garage to do some maintenance work. I wanted to move forward just a bit farther and the car won't start. All warning light illuminate and the battery is nearly new (one month old). It has done this before, but then started on the next try. Not sure what is going on.
- Year and Model: Many Volvos
- Been thanked: 76 times
It might be the PNP switch. Try rowing the shifter back and forth, quickly, a dozen times or so and then try again. You can also try to start it in neutral, sometimes with a flaky PNP it will start in neutral but not in park.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Additionally, check for corrosion of battery cables, in particular where the cable to the starter runs across the subframe. I've had a cable corrode right through i that spot and it wasn't noticeable until you actually physically moved the cable and saw that it was rusted clean through. That fault caused intermittent starting/stalling issues for quite a while before being diagnosed.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- 2810 Views
Last post by precopster
- 1981 Views
Last post by matthew1
- 378 Views
Last post by JimBee
- 3489 Views
Last post by Empathron
- 1039 Views
