Hey Fellow Volvo Appreciators, So this is the story.
Code 130 O2 sensor circuit malfunction(bank 1 sensor 1);
Code 141 O2 sensor heater circuit malfunction(bank1 sensor2);
Code 135 O2sensor heater circuit malfunction(bank1 sensor1)
Code 245 Turbocharger wastegate sensor solenoid low
Code 410 Secondary Air Injection Systyem Malfunction
Code 414 Secondary Air Injection System Switching, Valve A shorted
Code 445 Evaporative Emission Control System Purge Control Valve circuit shorted
Code 448 Evaporative Emission Control System vent control circuit shorted
The car was dead set against running. My once trusted main mechanic gave it back to me and said he thought it needed a computer. My new mechanic says it had a shorted out wire from an O2 sensor and a fried computer - literally you could smell that from 100 feet. A brand new Bosch MAF sensor was installed and a pick and pull computer from a 98 cross country was installed. She starts right up, I am getting 20 mpg average but she skips a beat once in about every hour of driving, like a little hiccup.
A friend of the new trusted mechanic who works at a Volvo dealer brought his gizmo down and said there are no shorts. I did buy 2 computers at pick n pull, have not plugged in the second one.
What would you do ?
Thank You, Jay
1998 v 70 awd 256 k 6 codes, runs fine
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Said codes are post ECU swap? How old are the o2 sensors?
- Has thanked: 311 times
- Been thanked: 817 times
I might pick up a junkyard MAF and swap it in, see if that solves the hiccup.
jaymorgan1
- Year and Model: 98 v 70 awd
Codes are post ecu swap. O2 sensor age - not sure. All codes say bank 1 is the problem, what is bank 1 ?
Thanks
Thanks
Oops I missed this comment, disregard my MAF suggestion. This is likely a problem with the O2 sensor(s), rspi was spot on.jaymorgan1 wrote:... A brand new Bosch MAF sensor was installed ...
Bank 1 sensor 1 is the front O2 sensor.
Bank 1 sensor 2 is the rear (post-cat) O2 sensor.
I don't know the exact setup of the O2 sensors on your XC but probably the front tone is the problem.
Another possibility is that there is a vacuum leak somewhere, be sure to check out all hoses thoroughly because if that is a problem, new O2 sensor(s) won't solve it.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
If the O2 sensors have more than 100K miles swap them right away or you are asking for trouble down the road. They should be considered a maintenance item at 100K unless you fancy replacing the much more expensive catalytic converter.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Regarding the hiccup....my car does the exact same thing. This might be a "unique" feature on 98' P80 cars with a turbo.
I talked with my indie mechanic about this who is a trained Volvo mechanic. He is extremely knowledgeable and very trustworthy and has the same car as me with nearly 300k on it. His car also has this hiccup (always had) and he has no clue as to what it could be. So I just live with it.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- E Showell
I've got the hiccup in a non-turbo '98, so I don't think the problem is unique to turbos. Moreover, if i stop at a light after the engine is warm, there can be a slight idle dip. Doesn't happen every time, but often enough to be noticeable.
'95 855 auto (sold)
'95 855 auto (sold)
jaymorgan1
So the hiccup is not unique to myself. Hmmm, if I figure it out I will announce the solution ! I have consistent rpm at idle so vacuum leak seems unlikely. Front o2 sensor is suspect. I wonder what triggers so many codes when the car performs very well. To be continued....
- E Showell
One thing I haven't checked is the brake booster vacuum line -- it is solo tucked away and a real pita to get to.
'95 855 auto (sold)
'95 855 auto (sold)
- 801 Views
Last post by rspi
- 1181 Views
Last post by dosbricks
- 21 Replies
- 11554 Views
- 1921 Views
Last post by volvolugnut
- 1270 Views
Last post by peacelover60
