The flap inside the box seems stuck. The motor and control unit (the knob) are working, and correctly so, but the spindle is shredded (now workable), but won't turn more than, say, 10 degrees, when it should rotate a total of about 90. I suspect inside the box issues.
How do I gain access to inside the heat distribution box to see why the flap is stuck and rectify?
1996 850 Defrost/Floor heat distribution flap
John850GLT
- Year and Model: 2000 V70R
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
MCC or ECC?
John850GLT
ECC
- Year and Model: Many Volvos
- Been thanked: 76 times
If the shaft itself is broken back inside the unit then you have a big job ahead of you. The only way I know of to replace the the damper is to pull the dash and remove the climate unit.
If, on the other hand, the socket on the end of the shaft is split then it can be repaired. There have been a variety of methods used that range from a short piece of fuel line and a couple of hose clamps to a cut .45 caliber (I think) pistol shell casing.
blandis
- Year and Model: 99 S70 T5
- Been thanked: 3 times
.40 Caliber casing fits perfect. I repaired one of mine. I cut the spent casing with a copper pipe cutter. Will deform the casing a bit... I worked it back into shape by sliding it over a set of needle nose pliers.
Brad
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
- 3884 Views
Last post by Ozark Lee
- 2547 Views
- 2151 Views
Last post by alschnertz
- 12 Replies
- 4848 Views
Last post by jimmy57
- 1186 Views
Last post by redc70
