2000 S40 inner tie rod removal and replacement
Anybody remove inner tie rods on a 2000 s40? I have been told by two shops that their computer programs are telling them that the rack and pinion need to be removed in order to remove inner tie rods. Is this correct? I know I can do it if I have the inner tie rod tool to remove them but I don't want to do this if I have to remove the rack and pinion. Any info on this job anyone can give me would be great! Very frustrated at this point. Outer tie rod ends seem to be fused on. Couldn't get the retaining nut loose at all. At this point they are going to have to be cut off.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
For the outer tie rod nut, I put an adjustable wrench on the nut and a wrench on the outer tie rod near the bolt, so the two wrenches sit like a scissor. then forced a cheating bar in between the two while keeping both wrenches together with one hand, so as to 'open' the scissor
maybe this can be of any help? http://www.volvoxc.com/0/resources/how- ... e-rods.pdf
- 2702 Views
Last post by manovlov
- 4244 Views
Last post by jimmy57
- 3544 Views
- 925 Views
Last post by precopster
- 1131 Views
Last post by cn90
