1992 740 Warning lights do not come on
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
jbwelker
Year and Model: 1992 Volvo 740
Post by jbwelker »
Can anyone tell me why all the warning lights on the dash don't come on when i turn on the car? The oil light and seat belt light come on and the one on the far left side (don't remember which one) work but none of the others do. I have replaced all the bulbs and re soldered all the solder joints but still no go. Is it the ECU? Is there a specific ground wire that could be the problem? Any help would be appreciated.
jbwelker
Post by jbwelker »
Small wire is conected to a spade conection on the alternator. Underneath the battery post on the altenator is a smaller insulated post with nothing hooked up to it. Is ther supossed to be anything coneccted to this terminal?
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
jbwelker wrote:warning lights ...oil light and seat belt light...
Oil light has a ground at oil pressure sensor, whereas seatbelt has its own circuit
If oil light lights up, it means there is voltage to other bulbs.
Your temp gauge works?
jbwelker
Post by jbwelker »
All guages work
93Regina
Post by 93Regina »
jbwelker wrote:All guages work
Check Engine light, Bulb fail light, and alternator light, for instance, are all supplied 12 volts like oil pressure light; so there must be a crack somewhere in that flat-copper printed board.
I'm reading via 1991 schematic, which shows a linear view...and may or may not show actual sequential sequence of this 12 volt bus supply. Gauges come first, then light bulbs. It shows Check Engine light as last in the "food chain" for 12 volts.
jbwelker
Post by jbwelker »
It was a bad alternator. Thanks for your help
93Regina
Post by 93Regina »
jbwelker wrote:It was a bad alternator.
Last I knew, those warning lights tend to light up when alternator is not charging, or when key is switched to on position.
At least on my buddy's 744, his lit up when alternator was dead, and engine was running.
This can be seen in the schematic....6 lights should light up when alternator's idiot bulb is lit up...those six diodes shown in schematic were installed for that reason, at least up to 1991 vehicles. Most interesting....
jbwelker
Post by jbwelker »
Yea it was a new one for me. My alternator died yesterday without the warning light coming on. So i started digging around and I found out with help from this thread and another post online that said to ground out the alternator exciter wire and see if the lights came on and they did.
Volvo Manic
Year and Model: V70,2000
Post by Volvo Manic »
The alternator failed on my daughters 850 and the warning lights lit up like a Christmas tree. Not just the battery symbol.
Are you saying that each diode is wired to turn on an individual indicator light if it goes bad? If s that would be a great feature as partial diode failures can sneak by other automakers warning systems without an indication.
Partial diode failure happened on my Benz Diesel. Fortunately she'll run until you turn her off, but lights would be nice, and I always drive with the lights full on, which will quickly deplete the battery with no alternator output.
