Replaced alternator/regulator due to overcharging (18 v) which fixed that and codes remained so swapped out ABS module from Midwest and still codes came back and car in limp mode.Any suggestions?
Unfortunately I'm in the sticks so hard to find shop that can troubleshoot and from what I've read swapping TCM on this year requires reprogramming.
1999 v70 xc p0605 & p1618 code.
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
What are you using to scan? Most generic scanners won't access the tcu so essentially you aren't finding out exactly what codes are coming g from the tcu nor are you able to clear it.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Using an Acutron pocket scan plus which up until now seemed to clear codes but not this time.Any way to clear stored codes other than taking it to a shop to see if these are issues related to ABS which I just swapped out?
Matty Moo
You could try pulling the battery cables for a bit but I can't say it will or will not work. You shouldn't be stuck in limp mode after a replacement either. Flashing arrow sure, but limp mode no.
Pull both battery cables, touch both together for a few seconds, reattach.
2000 s70 GLT
2014 Ram
- 1658 Views
Last post by bmdubya1198
- 1587 Views
Last post by wizechatmgr
- 967 Views
Last post by dandanboi25
- 658 Views
Last post by SinusoidalTendencies
- 1821 Views
Last post by Samtara1
