Why should a battery terminal crack?
EstVolvo
Year and Model: 2000 V70
Post by EstVolvo »
I had a car sitting for five months. The battery was dead and its positive terminal had a buildup that looked like a ball of ashes.
Once I cleaned everything I saw a crack around the terminal.
I haven't used any force around this terminal so it can't be mechanical damage.
Can anybody explain what may have caused the cracking?
What are the MIN and MAX marks on the side of the battery for? How are they supposed to be used?
How do I find out if the fluid level is correct?
Is there one big compartment for the fluid or many small ones?
If the liquid level is too low, what am I supposed to add in there?
How do I find out how old the battery is?
One side (positive) of the battery has a little white plug and the other side (negative) has just a little hole without a plug ... is it supposed to have one, two or no plugs?
JDS60R
Been thanked: 3 times
Post by JDS60R »
You can discard that battery. That terminal is lifted. Although there are many way for that to occur I commonly see over charging , sulfation or too much force on the terminal ( doesn't take much) .
The level marks are to mark the correct level of electrolyte in the battery. Looks like you have 6 openings . If you are not prepared to safely handle the acid in the battery it is best that you do not open it.
Your local volvo dealer will decode the numbers for you and tell you its age.
Retired
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Volvo doesn't want us to know it's age. When I called the dealer, they acted like they could not tell me.
dosbricks
Been thanked: 4 times
Post by dosbricks »
Setting for five months, the battery should have been disconnected and had a periodic maintenance charge. The electrolyte more than likely stratified and sulfated.
EstVolvo
Post by EstVolvo »
I did some more investigation and found two date stamps under the battery.
The battery seems to be close to 9 years old.
rspi
Post by rspi »
Nice job. Time for a change.
jimmy57
Been thanked: 322 times
Post by jimmy57 »
K6 is October 2006. The stamp in case is manufacture date for the case. 7F is a factory code.
db130
Year and Model: 2002 V70 T5
Post by db130 »
It took me a while to find K6 in the photos. :) Thanks for that.
I would have thought Feb 2006 judging by the stamps on the bottom.
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
