'97 855 Loose Battey Connector
vjaneczko
Year and Model: 2006 S60R
Been thanked: 7 times
Post by vjaneczko »
I noticed that the negative battery clamp is a little loose, even when the 10mm bolt is tightened as far as it will go. I'm wondering if there's some easy fix to this, besides replacing the whole cable. There's not enough slack in the cable to replace the clamp and I'd like to avoid replacing the whole cable. I've bent the soft metal but I'm sure it'll just get loose again. Any suggestions? I was thinking of wrapping the battery post with thin wire to buildup the diameter but that seems a little 'iffy' to have a lot of juice running through it - probably glow like a light bulb?
1997 855 GLT - R.I.P.
2006 S60R - For ME!
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
There are a lot of replaceable battery terminals on the market.Simply bolt the cable on it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
dosbricks
Been thanked: 4 times
Post by dosbricks »
Also make sure your battery is firmly secured so it doesn't move around, tug on the cable, and cause the connection to loosen.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
- Undo the battery cable end.
- Use a pair of pliers and gently bend the ends OUTWARD a tiny bit, all you need is 2mm or so.
- Re-install it, but only snug the bolt with 1 finger.
The #1 cause of loose battery cable is from over-tightening of the 10-mm bolt.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
+1 to cn90's idea.
Check if the tabs are bent, likely the ring itself can still snug up to the post if you bend them back out. To adjust them, all you have to do is unscrew and remove the 10 mm bolt.
Post by cn90 »
Another option is to file the parts where they mate together, this way it bites better.
