'99 V70. No start condition MVSOLVED. New batt cables
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Sitting in a parking lot unable to start my wife's V70. All the dash warning lights come on and I get a rapid click click click almost like the emergency flashers when I turn the key. Any advice while I await triple A?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I would say that your battery is flat.
Does warning lights disappears when you try to start the car?
If you have auto transmission...try to start it in "n"position.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Sounds right. try jumping it. the clicking is just not enough juice to hold the solenoid coil.
Current Volvos:
- Been thanked: 4063 times
Might be worth trying that ignition switch bypass wire.
- E Showell
Classic dead battery. I was away from the car for five minutes and new driver son had the lights on, seat heaters going, radio on, etc. with the engine off and that was, apparently enough to run the battery down in five minutes to prevent a start in 37 degree weather. The battery is an Interstate, new in May of 2013. Should a newish battery go flat after five minutes with that kind of load, or should I be concerned about a larger issue? The Triple A jump pack had us going instantly.
'95 855 auto (sold)
'95 855 auto (sold)
- misha
Remove it from the car,get it charged for at least 12 hours(slow charge).Remove the caps from the battery while charging,let it cool at least 2 hours before get it back into the car.
Or...just go out and buy a new battery.
I think that you can save this one with proper re-charging.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- E Showell
Thanks, Misha -- Sealed battery -- no caps. I have a trickle charger. Can I just leave it in the car with the trickle charger on it overnight?
'95 855 auto (sold)
'95 855 auto (sold)
- misha
Since it have no caps...i would remove it because it can explode IN the car.
Are you sure it's fully sealed?No caps even under the top labels?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- E Showell
Pretty sure no caps, but I'll check when I have access to the car next.
'95 855 auto (sold)
'95 855 auto (sold)
- misha
However...i would remove it and get it re-charged away from the car.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
