My son drives a 2001 V70. Right now you can not use the key to lock or unlock it which means it isn't secure to go places like his school. You cannot use the switch on the inside either but even if you could lock it, there would be no way to get back into the vehicle. A local repair facility thought it was the Master Power Window Switch part number 9452959. I have replaced that but while the windows go up and down, the locks are still unable to lock or unlock.
I've never seen a vehicle that when you put the key in the lock it will not manually lock or unlock the door. What else should I be looking at to solve it?
2001 V70 Unable to lock or unlock with key
JRL
- Year and Model: Several
- Been thanked: 16 times
Sounds like a low battery
Unless the battery is good (perfect), these cars do not like it and will do very weird things
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Does the key turn into the lock at all?
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
When you lock/unlock with key a signal is sent to a door module then the module responds by activating a lock actuator. It sounds like a door module either has no power, or is defective or locked. Some troubleahooting required and wiring diagram needed. Try disconnecting the batt for a few mins then reconnect for a hard reset.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
- 1249 Views
Last post by DavidE7
- 677 Views
Last post by micah
- 1197 Views
Last post by nsjames
- 1559 Views
Last post by jonesboy1983
- 1794 Views
