2007 S80 Front end suspension clunk
ninefiveone
Year and Model: S80 2007
Post by ninefiveone »
My S80 has a intermittent front end clunk I have worked all the TSB's and its still present, its more noticeable when the weather is cold outside under 50 degrees.
jbkeene
Year and Model: 2000, S80, NA
Post by jbkeene »
I had something similar once-upon-a-time
turned out to be a bad upper spring seat
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The upper spring seat is a common issue. Also check the upper strut bolt (under the hood) is well tight. The torsion bar end links are also known to fail and get noisy.
jimmy57
Been thanked: 322 times
Post by jimmy57 »
The P3 platform models do not have the same upper spring seat and have no issues with that as a result.
The other suspects that can be noises on P2 models can also affect P3 models but usually at much higher mileage. Check the upper strut bearing plate, the sway car connector links, and see if there is any indication of the subframe mounts moving in subframe (even though the TSB's have been done).
When does it do the clunk?
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
jimmy57 wrote:...
Pertinent question!
Beck
Year and Model: 04 V70 2.5T AWD
Post by Beck »
Really need to know when it chunks. For example does it clunk on one side only?
ninefiveone
Sorry it took so long to respond Im a newbie hopefully Im doing this right. I have had new struts installed the sway bar ends checked out. The noise happens on both sides usually just going up or down a driveway at slow speeds it does not make the clunk all the time that what makes hard to find. The ambient temperature seems to have a lot do with it in the summer the clunk pretty much disappears when the weather turns cold it reappears. Thanks hope this answers the questions presented
Beck
Post by Beck »
My dad had a temperature related clunk. Turned out to be his spring seats. Always use the XC90 spring seats - they are beefier.
jimmy57
Post by jimmy57 »
That is a known issue with early P3's when the front suspension is twisted. One side will get loaded and the other side gets unloaded when you turn off the street into a raised driveway. It is related to the subframe mount bushings. Who worked on the car and performed the TSB fixes?
The P2 S80 (99-06) does share the spring seats with 2003-2014 XC90.
The 2007-> S80 uses a different strut design with a different spring seat and strut bearing design.
ninefiveone
I have a independent Volvo shop I deal with I have built a trusting relationship with the shop they are also stumped by the clunk. I have some questions to run by them on Monday I'll keep you posted.
