I have found a 2005 XC90, single owner, 94000 miles, good price. The vehicle is in good condition, needs some minor things done to it. I have seen a lot of info on transmission issues that concern me. It also will need a timing belt and other belts replaced.
What else should I consider before buying?
2005 XC90 T6, advice needed, interested in buying one
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
On the T6 engine XC90s, the transmission fails every 50000 miles or so. Good chance the owner is already on the second transmission, and it's getting rid of the car before it fails again.
http://forums.edmunds.com/discussion/97 ... ansmission
However, all other engine models have reliable transmissions on this vehicle.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Check the stability relay in the floor under the amp under the passenger seat, they tend to get wet because of sunroof drain clogs, and the relay is about $500. Also, it takes out your stability control and all-wheel-drive. I think it affects ABS also. Alarm siren circuit will affect sunroof operability. It's only $200.
Current Volvos:
- 21 Replies
- 3122 Views
Last post by j-dawg
- 593 Views
Last post by CIK7
- 14 Replies
- 1326 Views
Last post by RickHaleParker
- 2116 Views
Last post by Ommynous
- 11242 Views
Last post by SuperHerman
