How do you know if the turbo is working - I do not hear or feel any spooling up. Car runs fine, gets 20 mpg average. In a previous post I listed 6 codes it is currently throwing.
Thanks
1998 v 70 awd 256 k check turbo boost ?
1998v70xcbill
- Year and Model: 1998v70xc
- Been thanked: 3 times
I have a v70xc 1998, never checked boost yet. My wish list is a installed gauge. Very easy to add a temporary gauge to manifold and run in car. My car has so much power I assume the turbo is working. I don't hear the turbo spool up. I have 200k. The turbo's on volvo's seem reliable. I checked the turbine for play at inlet. I do have oil dripping from turbo. To cold to deal with now. No drips on ground.
jaymorgan1
- Year and Model: 98 v 70 awd
Is there a port to tap into as to avoid drilling and tapping ?
Thanks for the info
Thanks for the info
1998v70xcbill
Yes, I would connect to Intake manifold (after throttle valve), There is a plastic mini manifold (just after Throttle valve) with ports blanked off with rubber caps.
- Has thanked: 311 times
- Been thanked: 817 times
That mini manifold is sometimes called the vacuum tree, I agree that's a good place to hook up a boost gauge.1998v70xcbill wrote:Yes, I would connect to Intake manifold (after throttle valve), There is a plastic mini manifold (just after Throttle valve) with ports blanked off with rubber caps.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Every turbo car should have a boost gauge. They sell ok gauges for as low as $15 on eBay. If you don't have one you really have no idea is the system is functioning properly. You can be under boosting (taking performance away) or over boosting (risking destroying your motor).
- rspi
Contact rspi..
- 18 Replies
- 3643 Views
Last post by jaymorgan1
- 21 Replies
- 5383 Views
Last post by j-dawg
- 11 Replies
- 1348 Views
Last post by erikv11
- 422 Views
Last post by viscous
- 15 Replies
- 3545 Views
