Does anyone know if the 30mm nut that holds the prop shaft collar is reverse threads? (I have to remove that in order to get the down pipe up in from underneath & I do not want to have to remove the whole bevel case.) Thanks, Royce
1:46pm UPDATE: The nut is not reverse threads; I finally go it off, but the collar (or as Volvo calls it Companion Flange) will not budge. So it appears I'll be dropping the bevel gear case. Does it leak oil out all over when dropping it down?
1998 V70xc Prop shaft collar nut
pedal2metal
- Year and Model: 1998 V70xc
'98 V70xc, '03 gti 1.8t, '99 F150, '90 Corrado, '80 Scirocco
precopster
- Year and Model: Lots
- Been thanked: 128 times
The casing has a breather tube on top. Just be sure you don't tip it over while extracting it.
- 8655 Views
Last post by Ou2mame
- 3117 Views
Last post by carboncow
- 4355 Views
Last post by rollin_home
- 4880 Views
Last post by cass3958
- 54 Replies
- 10955 Views
Last post by GreenMagicMan
