I know the LPT block was 2.4L while HPT was 2.3L allowing thicker cylinder walls.
I had heard the heads and valves are the same with the sodium core exhaust valves I believe?
My reason for thinking about it is the fact that I plan on doing maintenance on the '98 XC I had recently picked up. PCV, etc...
While I have the engine half apart, I have some very nice upgrade parts to bolt right on.
I have gathered, (horded) 3" throttle body from N/A and manifold with 960 throttle plate. The same modification I had done to the Wagon.
Recent junkyard find on a '98 T5, ECU 607 and 16T turbo with no slack at all.
I will check compression and integrity of the engine. It is not young at 210k, but If I blow it up..? It was meant to be.
I can fix it." My dad is a TV repair man, he has the ultimate set of tools." -Spicolli.
I also have an R exhaust manifold itching to do something.
There is time to contemplate over the winter.
No Play at all in the turbo shaft!
Are Lpt heads the same as Hpt in 1998?
Ben850
- Been thanked: 7 times
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Ben850
I will update when I dig into this idea.
Ben850
Said funny things (to me I guess) and had to delete.
Apologies.
Apologies.
Ben850
It is alright if no one may answer.
I understand, I have a 1967 small block .202 I was thinking of giving a try. Wait...
Smile!
Smile!
- Year and Model: Many Volvos
- Been thanked: 76 times
Did you happen to read this Fast Friday post from Lucky.
https://www.matthewsvolvosite.com/forums ... hp?t=51736
Ben850
I do remember reading that one. It answers a few things, but not the original head question.Ozark Lee wrote:Did you happen to read this Fast Friday post from Lucky.
I remember seeing it mentioned somewhere, I simply don't remember where. I didn't think I would find myself needing that information.
I try to pay more attention these days. Needing to know immediately or not.
- 18 Replies
- 2511 Views
- 2528 Views
Last post by Racerxc70
- 644 Views
Last post by foggydogg
- 2073 Views
Last post by mecheng
- 34 Replies
- 8591 Views
Last post by wizechatmgr
