I bought the Autel MaxiDiag EU 702 awhile ago and just tried using it for the first time. With key off, after plugging into OBD II socket menus come up right away. After selecting Volvo > Petrol (tried SRS and other options on that menu also), and trying the various model options, I'm getting the error message: Autel is not communicating with vehicle control unit".
Is there are trick to using the Autel that I'm not grasping?
96 855 T Autel code reader not working
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
On my 96 the car had to be running to communicate. Also make sure your cig lighter fuse isn't blown out.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
The printed box the Autel came in lists 96 Volvo and later, all that have OBD II so I'm thinking it should work.
Matty, the cig lighter? Does that affect the OBD II socket? More info?
- Has thanked: 311 times
- Been thanked: 817 times
I see the same thing with the EU102, the engine must be running in which case it works great. I use it on all of my Volvos (95-98). No experience with the cig lighter fuse.
JimBee
Erik, Matty, others,
Not to be picky, but do you have the EU 102 or 702? Mine is the 702. I'm just wondering if there's any difference. I did start the engine and ran the reader through the menus a couple of times, but continued to get the "not connecting to controller" message.
I didn't hot-plug the reader into the OBD II with the engine running? Should that make a difference?
What specific settings do you choose for the vehicle type? My reader doesn't list the 850 per se. And other specific settings?
Thanks!
Thanks!
I have that scanner and mine only works when I select the generic OBD II option, and it doesn't link when select the Volvo menu.
2008, C70, 44,000 miles
2000, S70, GLT, 67,000 miles
1995, 850, GLT, 144,000 Miles
1996, 850, Turbo, 226,000 Miles (TMU)
precopster
- Year and Model: Lots
- Been thanked: 128 times
I sell these over here in Oz and out of perhaps 15, I suplied a faulty one that had to be returned. It had the same error as yours.
Try it on another car using EOBD menu. It should at least pick up engine and trans ECUs even if not connected to a Volvo.
Matty Moo
Power to the obd port is through the same fuse for the cig lighter.
I do have the 702
I do have the 702
2000 s70 GLT
2014 Ram
- 1097 Views
Last post by jonesg
- 20 Replies
- 4766 Views
Last post by smacknab
- 2468 Views
Last post by Sommerfeldt
- 4500 Views
Last post by Liliflower
- 2704 Views
