Need rear trailing arm bushing procedure w/ photos Volvo 850
Baptiste1106
Year and Model: 850 1994
Been thanked: 2 times
Post by Baptiste1106 »
Anyone have a good write to to change the trailing arm bushings on a Volvo 850
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
skloon
Year and Model: 94 850 95 850 04 S60
Post by skloon »
Point to remember -- take a picture as the links can be installed upside down- you will notice when you try to install the second one- pray that the bolts aren't seized in place, if so you will need a sawzall to cut them out- easier if you undo both trailing arm ends and drop the whole shebang- the brake lines give enough slack for this as do the abs wires
blandis
Year and Model: 99 S70 T5
Been thanked: 3 times
Post by blandis »
I did both of mine a few months ago. No pictures that will help much. Passenger side is easy. Drivers side takes a bit more coaxing. I soaked everything in PB the night before....no issues with seized bolts. Only used 6pt sockets which is key.
Brad
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
Baptiste1106
I actually ended up dropping the whole back. Not too bad of a job. No bolts seized on me. I reassembled every nut & bolt w/ anti-seize and loctite. Got the alignment the very next day. From what i was told, the rear camber has no adjustment recommended from manufacturers. Is this true ?
h20ham
Year and Model: 1998 xc
Post by h20ham »
What happens if a trailing arm gets stripped
Asking cuz i cant get it to tighten
On a Canadian 95 with 500,000km, suspect there is some rust/corrosion
I plan on dropping the rear and thread chasing, or new threads i guess?
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
95 965 T shift controller in progress
05 xc90 rough idle
Has thanked: 1609 times
Been thanked: 4065 times
What’s stripped? The bushings on the trailing arms inboard or the big nut on the delta link going up into the frame?
h20ham
Post by h20ham »
The threads on the actual trailing arm inboard, the long bolt that goes into the arm through the 3 bolt hole bushing housing.
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
alschnertz
Year and Model: 1995 854T
Has thanked: 2 times
Been thanked: 12 times
Post by alschnertz »
I've been putting this repair off for years (shame) on a '95 854T.
This post is a good reminder to get it done.
'84 Prelude
'06 MPV
'13 Ford Focus SE
h20ham
Post by h20ham »
Or am I daft, and I should replace the entire D link
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
