XC90 going into limp mode when engaging cruise control
Twice in the last two days, when resuming cruise control the car has given the "Reduced Engine Power" warning. If I pull over and restart, then the error is cleared and the car drives normally. It really only seems to happen in conjunction with the cruise control. The dealer can't find any error codes either. Is this a failing ETM or is it more likely something else?
precopster
- Year and Model: Lots
- Been thanked: 128 times
The XC90 does not have an ETM but has a drive by wire system by Bosch which replaced the ETM by Magnetti Marelli in 2003.
You may have already found the answer to this question however for the benefit of those XC90 owners who have had similar problems it is more likely another problem in the vehicle. There may be a relay or a control error.
Electronic Throttle Body problems always occur during normal driving. If car goes into limp mode during normal driving cruise control is not permitted by the car's engine management system.
Did a reload of engine management software fix your problem Valheru?
- 1915 Views
Last post by ElVee
- 1756 Views
Last post by RickHaleParker
- 3178 Views
Last post by c70_lindsay
- 15 Replies
- 5078 Views
- 4306 Views
Last post by jonesg
