Over the Christmas break we took our car on a camping trip. Intermittently the car refused to start;
* Engine doesn't turn over
* A single click is heard
* Battery has been recently replaced
* But car had been standing for a while
* Jump starting the car didn't help, and neither did fully charging the battery from a battery charger (Voltage at terminals shows 12.7v when car is stopped)
* I tried connecting pin 87 -> 30 at the fuel pump relay and the engine cranked
* If I left the car for a bit and tried again it will sometimes start
Today, I disconnected the antennae ring and then reconnected it and the car started working. But then next time I tried it didn't work.
I also read that the starter inhibitor switch on the auto shifter can cause this, but when I removed a few sections of the console, it wasn't obvious where this switch was located.
I've ordered a new ignition switch and the antennae ring to try and see if this fixes it. Any other ideas what it may be?
2001 XC70 Clicks but won't start
- regent
- Has thanked: 2 times
- Been thanked: 12 times
Check your B+ (Battery positive) supply terminal at the main fusebox (inside the engine compartment); look for discoloration, loose crimp, corrosion, etc. This is a known offender point. (I am assuming you have already ruled out the terminal connections at the battery itself)
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
95% it's starter. Wiggle small wire next time it refuses to start.. If the car starts after that, you may want to clean contacts thoroughly, both sides, pry spring in plug part, so it is more tight, and apply some dielectric grease.
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
If the click comes from engine bay that's the starter solenoid that kicks in but may not "make" the contact to starter motor. You can test that with voltmeter or check light. If that works then it's worn brushes in starter making intermittent contact. That's all true if regent's test passes.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
surfziggy
- Year and Model: XC70 2001
Great, will try this today. I already cleaned the battery connections and the main earth connection.
draser
Is AMF4 pulled in when you jump its contacts, is that where the click comes from? You tried swapping the relay?
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
Yours is a single click, but mine are clicking as long as I have the ignition in the start positionsurfziggy wrote: 04 Jan 2015, 21:34 * A single click is heard
Please, any instructions on how to really do the "87 to 30" pin connecting? I could not find how to do that. Also, when you say "the engine cranked", do you mean it just 'turned' or the car started?
Also, what about the antenna ring you mentioned?
Thanks and cheers.
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Oka wrote: 13 Jun 2018, 08:44Yours is a single click, but mine are clicking as long as I have the ignition in the start positionsurfziggy wrote: 04 Jan 2015, 21:34 * A single click is heard
Thanks and cheers.
I would start by measuring the battery. Also try jump start the engine see what it does. If replacing the battery is good to have an eye on the new one in case there is a parasitic drain or an issue with the alternator.
- 1155 Views
Last post by magister
- 1744 Views
Last post by jpac
- 1382 Views
Last post by AKJeeper
- 1092 Views
Last post by June
- 534 Views
Last post by readallthebooks
