IPD sale Volvo Parts
2001 XC70 Clicks but won't start
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" cars.
2001 - 2007 XC-70
surfziggy
Year and Model: XC70 2001
Post by surfziggy » Sun Jan 04, 2015 9:34 pm
Over the Christmas break we took our car on a camping trip. Intermittently the car refused to start;
* Engine doesn't turn over
* A single click is heard
* Battery has been recently replaced
* But car had been standing for a while
* Jump starting the car didn't help, and neither did fully charging the battery from a battery charger (Voltage at terminals shows 12.7v when car is stopped)
* I tried connecting pin 87 -> 30 at the fuel pump relay and the engine cranked
* If I left the car for a bit and tried again it will sometimes start
Today, I disconnected the antennae ring and then reconnected it and the car started working. But then next time I tried it didn't work.
I also read that the starter inhibitor switch on the auto shifter can cause this, but when I removed a few sections of the console, it wasn't obvious where this switch was located.
I've ordered a new ignition switch and the antennae ring to try and see if this fixes it. Any other ideas what it may be?
regent
Year and Model: 2015 XC60 T5
Been thanked: 5 times
United States of America
Re: 2001 XC70 Clicks but won't start
Post by regent » Mon Jan 05, 2015 8:36 am
Check your B+ (Battery positive) supply terminal at the main fusebox (inside the engine compartment); look for discoloration, loose crimp, corrosion, etc. This is a known offender point. (I am assuming you have already ruled out the terminal connections at the battery itself)
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 non-turbo - lovely!/used to be... Now retired :(
1987 340 DL (with the 4-cyl N/A Renault Diesel engine, 5-speed manual, RWD) - sold (I wish I did not have to...)
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 7 times
Post by vtl » Mon Jan 05, 2015 9:15 am
95% it's starter. Wiggle small wire next time it refuses to start.. If the car starts after that, you may want to clean contacts thoroughly, both sides, pry spring in plug part, so it is more tight, and apply some dielectric grease.
2002 V70 (sold)
2005 XC70 (Telos Road took it. Did a chassis swap...)
2016 XC60
draser
Year and Model: 2005 S60 2.5T
Post by draser » Mon Jan 05, 2015 11:01 am
If the click comes from engine bay that's the starter solenoid that kicks in but may not "make" the contact to starter motor. You can test that with voltmeter or check light. If that works then it's worn brushes in starter making intermittent contact. That's all true if regent's test passes.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
surfziggy
Post by surfziggy » Mon Jan 05, 2015 8:27 pm
I was originally thinking it's starter, but as I mentioned, when I jump terminals 30& 87 on relay AMF4 the engine turns over just fine. So surely it can't be?
surfziggy
Post by surfziggy » Mon Jan 05, 2015 8:28 pm
Great, will try this today. I already cleaned the battery connections and the main earth connection.
draser
Post by draser » Tue Jan 06, 2015 6:50 am
Is AMF4 pulled in when you jump its contacts, is that where the click comes from? You tried swapping the relay?
surfziggy
Post by surfziggy » Tue Jan 20, 2015 12:53 am
I fixed it by changing the ignition switch and the antennae ring parts. These are both accessed by removing the cover around the steering column/indicator switches.
Oka
Year and Model: XC70, 2001
Post by Oka » Wed Jun 13, 2018 8:44 am
Yours is a single click, but mine are clicking as long as I have the ignition in the start position
Please, any instructions on how to really do the "87 to 30" pin connecting? I could not find how to do that. Also, when you say "the engine cranked", do you mean it just 'turned' or the car started?
Also, what about the antenna ring you mentioned?
Thanks and cheers.
1985 BMW (E23) 735i(US)/AUTO/209K Miles
1997 Mazda MPV/AUTO/4WD/173K Miles
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles (Brown)
2001 Volvo XC70/AWD/Auto/Turbo/144kMiles (Burgundy)
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
oragex
Year and Model: S60 2003
Has thanked: 71 times
Been thanked: 113 times
Canada
Post by oragex » Wed Jun 13, 2018 9:46 am
Thanks and cheers.
I would start by measuring the battery. Also try jump start the engine see what it does. If replacing the battery is good to have an eye on the new one in case there is a parasitic drain or an issue with the alternator.
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
Who is online
Users browsing this forum: 537playing, EngineeringBloke and 42 guests
