My buddy has this issue and the scan with his OBD2. Haven't had time to put in Vida Dice yet. He pulled TB and it was terrible...cleaned it up and issue persisted.
Q: Is this talking the TB or the pedal assemble...as I'm assuming it may be fly be wire,no?
2004 XC70 P2111 Throttle Actuator Control System
carboncow
- Year and Model: 2003 XC70 2018 S60
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Throttle, not accel pedal sensor code. It is the one for throttle detected open more than the desired amount. Usually a potentiometer or wire connector issue. On that car the throttle unit connector is problematic over 125K miles. Best fix is 6 wire leads with terminals and connector housing to replace the one on it now. The terminals have been improved. If the connector is unplugged and the pins and terminals are cleaned and dielectric grease applied it might take care of it for a while. If it fixes it for a few thousand miles then you have confirmed the connector is it.
- 3029 Views
Last post by RickHaleParker
- 3276 Views
Last post by mrbrian200
- 3062 Views
- 35 Replies
- 5745 Views
Last post by XC70Rider
- 6849 Views
Last post by hcritz
