noticed car had a very slight surging today at 60 mph, then car went into limp mode with "reduced engine performance" displayed and motor would only reach 1800 rpm. drove 1 mile at 15 mph (max speed) that it would go, to a place to pull off and park. shut car off, restarted and car ran normal. drove home 25 miles and everything normal.
no display message after restarting. what should I do to diagnose?
2007 xc 70 code " reduced engine performance"
raquette
- Year and Model: 2010 xc90, 2007 xc70
- Been thanked: 4 times
I'll also add the car has 116,000 miles, and that the cruise control had been working intermittently and would "kick out" when it wanted to. lately though (last 2,000 mile) this has not happened.
beachmedic78
- Year and Model: 1997 V70 2.4T
A lot of things could cause this unfortunately. Without a code it will be hard to start diagnostics. Does anything look unusual in the engine bay? If the turbo or waste gate died, performance would suffer a lot. It would still run smooth but have almost no power compared to normal. Any strange noises?
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
Can you rent out a code scanner and do a scan of maf, fuel trims, throttle and pedal position, engine load?
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
raquette
I have a scanner and no codes stored. no strange noises.
replaced air filter today (could not see through the old one). I have driven this 35 miles since this happened with no additional problem. Has always idled fine even when the limp mode occured.
I'm thinking of carry my scanner if this happens again before any reset occurs by restarting.
I read elsewhere in this forum that the throttle opening plate can get crud and deposit on it and may be the culprit?
Anyone who has any similar problem please report your experience.
Thanks All!
Thanks All!
beachmedic78
If it is crud on the throttle plate, I've had good results using SeaFoam intake cleaner before.
mrscullini
- Year and Model: 05 XC70, 08 XC70
- Has thanked: 1 time
i had a similar situation recently, however, i did throw misfire codes. when did you last replace plugs and/or coils? i have posted live data numbers in another thread. see if your scanner can pull data for comparison.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
+1draser wrote:Can you rent out a code scanner and do a scan of maf, fuel trims, throttle and pedal position, engine load?
Very likely!
ECU is working hard to keep it afloat.
Just not low enough to trigger CEL.
Clean MAF sensor as first step, no cost to you.
- 20 Replies
- 15743 Views
Last post by mrbrian200
- 566 Views
- 13 Replies
- 1538 Views
Last post by firstv70volvo
- 6242 Views
Last post by oragex
- 2992 Views
Last post by mickenann
