Leak on Drivers side floor rug
sisterocean
- Year and Model: 2007 V70
Anybody have a damp rug? Not sure if its coming from windsheild or underneath car? For sure its coming from rain? Any comments appreciated
sisterocean
Thank you so much. It is probably whats wrong. Learning way more than I wanted to. Car is 16 yrs old
JRL
- Year and Model: Several
- Been thanked: 16 times
Or the sunroof drains are clogged
- misha
- Has thanked: 155 times
- Been thanked: 432 times
...or draining holes on both sides on front of the car by the windshield are clogged.
If it's from a rain or a car wash that's it.
Open the hood and you will see two draining hoses on the left and right side of the plastic shield under the wipers.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Been thanked: 504 times
1+,kahl wrote:Last time I had damp carpet on the drivers side it was the heater core leaking. Does the wet smell like antifreeze?
O.P, check your coolant reservoir level first.
As you can see, there are multiple options (they covered every single one)
A good place to start would be to decide if it is water or coolant. wipe/touch carpet with your finger and dab onto tip of tongue: coolant is very bitter and doesnt take much to taste it on tip of tongue. If bitter: heater core. If water: coming from somewhere else.
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
- humbertoflores63
- Year and Model: 1995, 97, 98
- Has thanked: 1 time
Check the location of the cabin filter, right by outside corner is drain. Make sure to clean this first.
- 28 Replies
- 1749 Views
Last post by MrAl
- 610 Views
- 23 Replies
- 6017 Views
Last post by roscoerich
- 335 Views
- 979 Views
Last post by odaikorob
