Greetings!
I have a post here about my current issue, and realized that I'll need to order everything tomorrow morning to get it in time.
I'll be replacing the ECT and thermostat, and since it looks like it's about to disintegrate at any moment, I want to replace the big black hose that runs to it too. Unfortunately, I can't find anywhere what it is called or what part number it is.
I searched around the forums but couldn't find any pictures indicating, it or part numbers that definitely referred to that individual hose.
If anyone knows off the top of their head what the part # on the black hose that runs to that is, or specifically what it's named so I can find the part #, I'd appreciate it. I believe it's a coolant hose, the one that runs right next to the power steering fluid reservoir.
Thanks to any night owls that can help me out!
1998 V70 T5 Hose Identification
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 28 times
- Been thanked: 22 times
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
villagepc
- Year and Model: 98 V70m | Stage III
- Has thanked: 3 times
- Been thanked: 2 times
Upper radiator hose ? That would be the big one. Runs to the front of the motor, connects to the radiator. There's another little hose that runs from the top of the thermostat housing and connects to a nipple on the reservoir tank. Not sure what they call that one, probably reservoir hose. While you're hosing around - take a look at the hose running from the bottom of your reservoir tank to the back of the motor... if your upper radiator hose is wonky, that one might be too. Think that one's just a regular heater hose sized hose... nothing special. It's not a metric hose that I'm aware of.
Here's a couple of threads regarding vacuum lines.
https://www.matthewsvolvosite.com/forums ... f=1&t=6941
and hard starts
https://www.matthewsvolvosite.com/forums ... 9&p=308705
hope it helps
and hard starts
hope it helps
____________________________________________
1998 V70 T5M R Clone | IPD / ARD Stage 3
2008 S80 3.2 - not too shabby
1991 740 Turbo - 2.5" lift, 100% madness
- WagonLagan
- Year and Model: 1998 V70 T5
Awesome gmh, exactly what I was looking for, thanks!gmh wrote:This one?
https://www.fcpeuro.com/products/volvo- ... -1335433oe
villagepc wrote:While you're hosing around -
Really appreciate that idea!villagepc wrote: take a look at the hose running from the bottom of your reservoir tank to the back of the motor... if your upper radiator hose is wonky, that one might be too. Think that one's just a regular heater hose sized hose... nothing special. It's not a metric hose that I'm aware of.
Any thoughts on what the part number or specific size might be? I have some 5/8" heater hose left over from a PCV system mod, but I'd like to know if I need another size before I pull it out of there as it's my only transportation.
I found these, but none look right to me.
EDIT: Here we go.(Thank you again Robert!!) It's got to be one of these, upper or lower reservoir hose I presume.
You think heater hose would work just as well assuming I can figure out the needed size villagepc/anyone else?
Thanks a lot for any insight on that!
- Been thanked: 504 times
At this mileage, consider doing them all:
- Upper and Lower Rad hoses
- New reservoir (mine cracked at 110K) + cap
- Hoses x2 (to and from) reservoir
- Turbo coolant hoses x2
- WagonLagan
I'm in full agreement with you there, and thanks for laying them all out with names. That'd be a pretty penny though and sadly I just do not have the money or time for it just yet. Those hoses look to be $15-20 a piece. I'm planning on replacing my hoses in the near future. Any possibility of getting through some/all of it with heater hose?cn90 wrote:At this mileage, consider doing them all:
BTW cn90, hope you saw that I was finally able to post results from that experiment you requested!
The results weren't very interesting or surprising, however.
- 677 Views
- 3584 Views
Last post by jefe
- 1850 Views
Last post by jmscdgn
- 898 Views
Last post by congareelc
- 688 Views
Last post by ggleavitt
