1999 v70r etm cleaned now no throttle
mtngoat1976
- Year and Model: v70 1999
I cleaned the etm and reinstalled the unit. The car starts but, I have no throttle when stepping on the gas. The check engine light came on and when at ideal the rpm varied before cleaning . I am guessing the etm is done and i need a new one.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Codes?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
mtngoat1976
thanks guess I will have to get it to a shop to get it fixed.
- E Showell
By codes, I meant have you had the codes that are set when the check engine light illuminates read yet? If so, please post the alpha-numeric codes. That makes it much easier for members to offer advice as to what might actually be going on. Without any codes specified, we're shooting in the dark.
'95 855 auto (sold)
'95 855 auto (sold)
mtngoat1976
I did not have the codes ready. I did unplug the the etm and made sure connection was good. First round I did not leave the key in the ignition for 10 min to let the cpu understand were the TPS was. I did this last night and then let the car run for 20 mins and seems to be working great. I then took it out for a drive and car cut out no code but opened hood and heard a high pitch sound. Moving the wire harness to ETM sound went away but heard a click sound if moving the harness around and sound would come back. I will try to stable the harness tonight and try it again and let you know.
precopster
- Year and Model: Lots
- Been thanked: 128 times
Who on Earth told you to leave the key in PosII to have the ECU relearn the TPS position for a 99 model ?
That method only applies to the 2002 and on turbo Bosch units.
You can power the ETM harness by using one of the positives from the injector wire harness as a trigger through a relay and power up the large green wire on the ETM harness. Check earths on the engine block.
The main relay for the ETM is under the kidney shaped fuse box. Some 99s use the white air pump relay for ETM power.
- 14 Replies
- 2536 Views
Last post by Sommerfeldt
- 1060 Views
Last post by jbkeene
- 2782 Views
Last post by Ozark Lee
- 13 Replies
- 2252 Views
Last post by TheRev813
- 3398 Views
Last post by RickHaleParker
