Hi everyone,
My car just stalled while idling for about 15mins. in a parking lot. All of a sudden the rpm started fluctuating a little, and then it quit. At that time the CEL, trans. arrow, ABS and TRACS lights were on.
It started right back up again and the lights were all out. Drove back to work and everything seemed normal.
Do any of you guys know what this could be?
Thanks, Dirk
1998 V70XC stalled while idling
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
Could be either the ABS sensor which surprisingly can seriously affect the way the engine performs or the ETM - electronic throttle module. Rebuilt ABS sensors are reasonably priced and often have a very long guarantee on them. If you have the necessary torx driver and the will to do it it can be done in your driveway. I had to do one about 4 years ago and had the ETM done by the dealer last year. The dealer charged me $814.00 for the ETM. My guess is that it is probably the ABS sensor.
- 850 LPT
I never would have thought that a bad ABS sensor could cause stalling
My car does not have an ETM, only 99' and up have that. But I was wondering if a faulty MAF could cause this?
13' Honda Odyssey
13' Honda Odyssey
Ben850
- Been thanked: 7 times
Is this the first time? Or does this happen often.
It could be what I suspect to be a cracked, leaking link in the Evap system on my identical vehicle.
I also came up with a Barometric sensor error.
I haven't yet dug into the XC, but it starts and runs then stalls out. Pretty much what my '96 wagon did when I bought it.
At that time I had found a broken Evap hose at the roll over valve, but I swapped the MAF and front O2 sensors which may have helped.
The '96 did not have that extra MAP/Barometric sensor at the fender.
I'll figure that all out when I get to it.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- 850 LPT
This was the first time it happened. EVAP is ALL new, so I would really be surprised if there was anything wrong with it. Plus, wouldn't a fault in the EVAP throw a code fairly quickly?
I drove the car home after work (40 miles) on backroads, and it ran as smooth as ever, still no CEL. I'll just watch and see, but it bugs me not to know what caused this.
13' Honda Odyssey
13' Honda Odyssey
Ben850
Yes. Until deleted.mf70 wrote:Will a '98 store codes? A later car would "keep a record" of what happened for VIDA.
Also potential ignition switch, electrical part. Have you replaced that on your car??
Looks like you will be home for a few days this week
- 850 LPT
Hi Steve, yes we will have some digging to do out of this one
As far the ignition switch, I do not think that has been replaced. Good suggestion. And I did not check for codes, but maybe I should. The CEL is out and everything behaves normal, so I didn't think to check.
Thanks all,
Dirk
Thanks all,
Dirk
13' Honda Odyssey
13' Honda Odyssey
Ben850
Hey Steve, and Dirk,850 LPT wrote:Hi Steve, yes we will have some digging to do out of this one![]()
Thanks all,
Dirk
Let me know how things go with those issues.
As I said Dirk, My new acquisition is an exact duplicate of yours.
I now count on you for the good information.
Honestly,
P.
- 1266 Views
Last post by SuperHerman
- 1811 Views
Last post by TRuck
- 897 Views
Last post by hcampan
- 16 Replies
- 3075 Views
Last post by Sommerfeldt
- 15 Replies
- 4071 Views
Last post by shaker_chi
