93 240 overdrive problems
ordinaryboy1986
- Year and Model: 1993 Volvo 245
arrow light tends to come and go. couple of times car would get stuck in really high rpms on the freeway. sorta just feels off when changing gears. i had a realllllly bad oil leak because of a broken oil trap. lots of oil on the bottom of the car. thats been fixed but now the overdrive is acting up. got under the car and other than the wires being covered in oil the connections look good. there is a sorta buzzing noise when cars shifts at high rpm. would replacing the overdrive solenoid be something to consider? or maybe clean all the wires or even new wires. thanks everyone!
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Repair Volvo 240 Automatic Overdrive Relay - DIYordinaryboy1986 wrote:arrow light tends to come and go
Overdrive Relay and Function:, also see "Eliminating the Solenoid and the Manual Downshift System"
110397 - Automatic Over-Drive Solenoid Bypass Kit
ordinaryboy1986
picked a relay out of a old volvo and it fixed my problem. still makes a buzz vibrating noise when i shift into 3rd and 4th. but the high rpms are gone and i can drive over 55 mph. if anyone might know what that quick buzz is right before my car shifts i would be very excited. thanks everyone!
- 1473 Views
Last post by 93Regina
- 2827 Views
Last post by Nashsurecanpaint
- 20 Replies
- 3717 Views
Last post by smeha
- 4568 Views
- 3478 Views
Last post by reeltapegone
