Hi All,
I'm new to this forum, but not new to Volvos. I purchased an 850 non turbo that had overheated and I thought I could machine the head and get it back on the road. I just heard from the machine shop that the cylinder head is too distorted. They can't take more than 15 thousands off and my head would need more than that. I've started looking for a used head as a replacement. Can anyone please tell me what years are compatible. Also will a 1998 S/V70 head work. I see listings for cylinder heads with or without air pumps. I thought all 850's had an air pump for emissions. This is a great site, thanks in advance for the help. Matt
1995 850GLT non turbo cylinder head compatibility
- Year and Model: Many Volvos
- Been thanked: 76 times
Welcome to MVS.
For a non turbo you can use about any head, turbo or non turbo, late '94 through '98. Some 850s have SAS and some don't but you can always trick the ECU into thinking that it is there and working if your car was so equipped with a Radio Shack diode. It is a very simple procedure and the details are in the repair database. Just search "SAS delete".
I only have one Volvo with SAS, the '98 S70, and I didn't think there was a difference in the head but I have never really looked that closely. The SAS air pump crapped out on it so I just did the delete trick to keep the CEL from coming on and left everything else in place.
If you had a turbo then only a turbo head should be used but the only differences between the turbo head and the NA head are in the way the exhaust valves are made.
- matt122s
- Year and Model: '98 V70R
Hi Lee,
Thanks for the helpful information on cylinder heads. I found a head in a wrecking yard with 96k on the engine for $200.00 I pick it up Monday and clean it up and replace the valve seals.
Thanks again, Matt
Thanks again, Matt
- 590 Views
Last post by Glencoeteen
- 1841 Views
- 2136 Views
Last post by precopster
- 971 Views
Last post by erikv11
- 13 Replies
- 8362 Views
Last post by lifeofgold
