I drive a S60 2.4 (LHD - 190.000km) and I am facing an intermittent problem with the cabin heating.
From time to time the temperature coming from the vents (right side) is very cold. Left side works correctly.
A OBD scanner shows a CCM-DD32 Right temperature damper motor error.
Will a re-calibration fix the issue?
2005 S60 CCM-DD32 Right temperature damper motor
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
Sounds like motor does not send signal to CCM that it's reached desired position or home. I'd check wiring and connector, and apply a few commands to see how it operates, looseness or noise in there.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
egoudriaan
- Year and Model: S60 2005
Hi Draser,
Will do some (visual) checks soon.
Thanks for your reply.
- 8432 Views
Last post by cn90
- 3876 Views
Last post by Blacklab467
- 3186 Views
Last post by mrbrian200
- 16 Replies
- 5090 Views
- 928 Views
Last post by bakkenolofsson
