The title pretty much says all. I need a new O2 sensor for the 850 and there are a few aftermarket ones for around 30 bucks but the Bosch are indeed fairly more pricey. Am I safe in getting an aftermarket one? Anyone have experience with these?
Thanks
1995 850 Turbo Aftermarket O2 sensor OK?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
It's better to go with UNIVERSAL Bosch and to crimp & solder wires and then to use shrink tube over the connections than use aftermarket one.
Maybe Ngk could be used from all aftermarket brands.
The crimping & soldering wires on universal o2 sensors is the most critical part of the job.If not done properly and if not protected properly it will be invisible to ecu or it would send wrong readings.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 1060 Views
Last post by MadeInJapan
- 2001 Views
Last post by 93Regina
- 3039 Views
Last post by oragex
- 876 Views
Last post by misha
- 1206 Views
Last post by dtmmoore2
