1999 Volvo V70 XC AWD rear wheel not norking anymore
kawish
Year and Model: V70 XC 1999
Post by kawish »
HI
I am new here and I have a 1999 Volvo V70 XC AWD and just find out by getting stuck that the AWD not working anymore and no warning no noise I don't understand and I need help could it be simple to fix ?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Greetings. Welcome to MVS.
Are you sure it ever worked? The prop shaft (drive shaft) to the rear differential is a know weakness on the early AWD cars and it is very common for that shaft to simply be removed once the joints or the carrier bearing go bad. The car continues to work as a FWD car and it will run forever that way but there won't be any drive to the rear wheels. The way to tell is to get underneath the car and look to see if there is indeed a drive shaft from just behind the engine to the rear axle.
I was all excited to have AWD when I bought my first XC only to learn later that the prop shaft had been removed.
If the drive shaft is there then chances are the transfer case (bevel gear, angle gear) is bad.
Has thanked: 2207 times
Been thanked: 1852 times
If the bevel gear has failed it will not transfer the power to the rear wheels even with the prop-shaft in place. Another culprit may be a failed viscous coupling unit which is fitted just in front of the rear axle with the prop-shaft connected to the front of it.
bskeels
Year and Model: 1997 Volvo 960
Been thanked: 3 times
Post by bskeels »
I had the splined coupler go bad on my 2000 XC which is between the bevel gear and the transmission
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
bskeels wrote:I had the splined coupler go bad on my 2000 XC which is between the bevel gear and the transmission
There is a cause for this to happen.
These couplers are designed to break in case something in the driveline locks up. In my case it was the viscous coupler that locked up and destroyed those splines. You end up with an FWD car when that happens.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
kawish
Post by kawish »
Ozark
Thanks for the reply, it was working before I was able to lunch my boat on a sandy beach in Mexico now I am getting stuck all the time and the front wheel are just spinning like never before just wondering if it is the coupler or the Bevel
Only way to find out is to remove the prop-shaft. Then try to turn the front wheels while off the ground and see if the rear flange on the angle gear turns. This is not conclusive but if the sleeve has failed, then there will be little or no turning.
Do you recall hearing a loud 'bang' at any point while driving the car or felt it? If the viscous coupler has failed/seized, then the angle gear may have failed in sympathy.
As for parts, as you are on the eastern side, try Erie Vo-Vo for parts.
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
Does anyone have diagrams of the drivetrain of the v70xc?
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
Post by Ozark Lee »
shiloh51933 wrote:Does anyone have diagrams of the drivetrain of the v70xc?
VADIS/VIDA have exploded parts diagrams but I don't think they are all on the same page. Some of the dealership websites, like Tasca Parts, have the diagrams online.
kawish
Post by kawish »
if the viscous cupling is not fonctionning properly or failed you will not have traction on the passenger front wheel no ? when I got stuck in the sand both wheels were spinning
