2009 S-60 Hard starting it does start ,but don't!
mikey41969
Year and Model: 2009
Post by mikey41969 »
Hi I am having problems starting my 2009 S-60 Volvo in the morning . When I do get started in the morning it is fine the rest of the day it is when it sits overnight.Would anyone know what to look for like a ground wire or fuel pump issue ? Just wanted to see if anyone else comes up with a answer to this problem. I want to get rid of the dam thing & get a S-60 AWD 2013 T-5. Thank you !
draser
Year and Model: 2005 S60 2.5T
Been thanked: 2 times
Post by draser »
Sounds like a cold start problem, normally related to coolant temp sensor. I'd scan engine parameters to get more info, like fuel press., etc.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
Vovo_merz
Year and Model: 2007 s60R
Post by Vovo_merz »
not sure if S60 has the same set up as never had problems like that in a s60 ( owned around 40 s60's) but s40 had a fuel pressure switch problem where all the fuel in injectors and lines would run back to the fuel tank over night that is why its only in the mornings or longer periods between starts
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
