Hello,
Hoping that someone might be able to help me. I have a V70, and last weekend the locks in the lift gate, rear doors (r and l) and fuel door stopped working. They will not work with the door lock inside the car, fuel door button, or the unlock on the key. The front doors (r and l) still work fine both inside the car and with the key. Any thoughts or ideas?
Thanks.
2006 V70 2.5T - Rear/Lift Gate/Fuel door won't lock/unlock
May not be relevant but I had an odd situation where the tail gate wouldn't open from outside...it turned out I had closed it and something in the boot was pushing against the back of the tail gate. Removed the obstruction and it opened but was a bit odd.
Have you checked for blown fuses? Is anything else not working, sunroof, auto dim mirror etc.?
If you can get the tailgate open,I don't know if there is an inside release handle which it sounds like you can't, Murphy's Law in action, I would disconnect the battery, following the procedures outlined on the forum, reconnect battery and then try the remote. Every time I had an odd electrical issue so far, this solved it.
2005 XC70, Dumb luck bargain.
2001 V70 XC, The learning experience.
2007 Frontier Crew Cab, The practical vehicle
1966 Datsun 2000 Roadster, Happiness on 4 wheels
1964 Datsun 1500 Roadster, Pile of parts, hibernating
After researching what each fuse controls, turns out there is a central locking system fuse that controls rear doors, lift gate, and fuel hatch. For some reason that fuse had blown. Replaced it and everything is back to normal and saved a diagnostic trip to the shop.
Thanks.
Thanks.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
I had a situation where the fuse kept blowing (very inconvenient at the gas station). Turned out to be damaged/shorting tailgate wiring in the LH tailgate hinge which is a very common problem.
https://www.matthewsvolvosite.com/forums ... =9&t=47882
- 14 Replies
- 2133 Views
Last post by MotorTheresa
- 932 Views
Last post by ggleavitt
- 2214 Views
Last post by aaronlife
- 1566 Views
Last post by jonesboy1983
- 16 Replies
- 8937 Views
