Yesterday when I was buying some PB Blaster I noticed a can of MAF cleaner on the shelf. I didn't know such a thing existed.
Is cleaning the MAF a good idea and if you've done that did it make a difference? My car runs a little rough but it runs well enough. I'm a little hesitant to mess with it and would just be inclined to proactively replace the MAF (the original) considering its age, but if cleaning it won't kill it I might give it a try.
98 V70 MAF sensor cleaning?
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
MAF would be best served if the air box is clean and air filter is replaced timely with the recommended make.
There is a DIY for cleaning MAF, be careful handling hoses, vac lines, and MAF itself. Old things break easily.
Work in room temperature.
- Has thanked: 311 times
- Been thanked: 817 times
MAF cleaning rarely does any good, except when the MAF is visibly dirty or oily. The cleaner is usually a last gasp effort on a dead or dying MAF that is throwing codes. The product is likely the same thing that is packaged up as "electronic parts cleaner" but given the sensitivity and expense of the MAF it is a good marketing ploy, I wouldn't use anything but the "MAF cleaner" product.
The MAF also rarely shows intermediate signs of wear, it either works fine or not at all. If the idle is just rough around the edges, I would look elsewhere first (ignition, vacuum lines, etc).
That is to say, a bad MAF will usually give a full stumble, constant or intermittent yes, but we are not talking about constant, minor effects on ignition.
- Been thanked: 4068 times
Proactively cleaning, no. No codes, good running, leave it alone.
- 793 Views
Last post by volvobro
- 389 Views
Last post by oragex
- 3714 Views
Last post by oragex
- 31 Replies
- 5892 Views
Last post by soulvoid1990
- 2107 Views
Last post by enriquepr21
